DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 04-21-2009, 10:57 AM
pherdog pherdog is offline
Default LR Wheel Speed Sensor Failure - ABS Light On
The ABS light on my 2003 Dodge Grand Caravan has been on for a couple of months. I had a buddy with an ABS code reader check the code and it came up LR Wheel Speed Sensor Failure. I changed the rear drivers side wheel speed sensor and the ABS light did not go off. Has anyone had this problem before? If so, how did you fix it?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-21-2009, 10:26 PM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
First I would ck to see if its plugged into the connector and two, reck to see if the sensor is upside down. Meaning was it installed right. If those are good, then you'll need to ohm ck the wires.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 04-22-2009, 11:21 AM
I'm pretty sure I installed it right but I'll double check. The wire connector clicked when I plugged it in and the sensor end has a groove on it to prevent it from being installed upside down. When thing that was strange is the new sensor had grease all over it. Not the wire connector end. The old sensor had no grease on it. I can understand it of the wire connection end would have some electrical grease on it, but I am a little confused why the sensor end would have grease on it.
Old 04-23-2009, 09:10 AM
All is good now. I went home last night and the ABS light no longer lights up. I didn't have my buddies ABS Tool to clear the code out after I put the new sensor on. It must continue to display for a period of time after it is fixed and then shuts off.
Tags
07, 2003, 2006, abs, caravan, change, dodge, grand, light, mustang, neon, ram, sensor, speed, sxt, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
