DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-04-2009, 09:17 PM
soloblazer soloblazer is offline
Default Immobilzer problems...Pleeez HELP!!!
I have a 04 model, every couple times i try to start it, it acts like the key is not the right key, so it will start up run for a couple seconds then die, i have had 2 keys made and also replaced the sensor that goes around the key cylinder. not sure what else it can be, sometimes it starts right up no problems, then the next time it acts like its the wrong key, even if i try to start it and it dies, i can cycle the key on and off without taking it out and it will start, code shows that its a invalid key. any ideas would be great.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-04-2009, 11:16 PM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
First of all, where did you buy the skim module from? and did you have the right pin code for both the module and keys? Any time you replace a module you do need to transfer the key code (pin) from the pcm.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 06-05-2009, 08:58 AM
the dealer put the new unit in and gave keys.
Old 06-05-2009, 11:37 AM
Then the dealer needs to fix the problem.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
