DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-09-2009, 06:12 PM
rickerho rickerho is offline
Default Transmision Problem? / Or Engine Knock? Help!
Hi, I have a 1997 grand caravan. When going up a steep hill and accelerating hard it makes an awful rattle noise that sounds just like pre ignition knock, and it seems to lose power if you keep your foot into it. Do you think this is pre ignition knock or could it be the torque converter? Would the knock sensor not take care of pre ignition?
Thanks in advance, any help would be greatly appreciated.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-09-2009, 06:32 PM
JoeC1981 JoeC1981 is offline
The knock sensor can only retard timing so much, but if it is sensing a ton of knock it will retard the timing so much that you can feel a loss of power. Try high octane gas and see if it gets better, if so you may need some combustion chamber cleaner to get rid of the pre-ignition. I don't think its a converter issue. When they go bad the engine RPM will be higher than usual, i havent heard a converter make a knocking noise.
Old 06-09-2009, 11:24 PM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
There are two ways if the torque is making a knocking sound, Loose bolts and cracked flex plate. Are driving a 3.0L or 3.3L engine? And do you have a ck engine lite on?
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 06-10-2009, 05:12 AM
Default Knock or trans.
I tried high octane fuel, still the same. It is a 3.3 litre. Only does it on really steep hill. No ck engine light.
Thanks for your previous input.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
