DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-09-2009, 08:58 PM
YOTA YOTA is offline
Default need some help with a chrysler town and county van
ok i know its not technically a dodge but its close right?
here goes my problem is when driving the van it shuts off completely and when it is running the lights flicker on and off, any thoughts? this is a 1993.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-09-2009, 11:18 PM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
You could have a charging problem, Bad ASD relay,or the wire harness is to close to the spark plug wires. The last one will throw a lot of people off.Because when the harness is too close to the wire and the age of the wire will sent RFI signal thru the system and cause transmission problems,when there is no problem. If you had a 1992 minivan i would tell to you to replace the speed sensor. Because this was a problem, cutting off fuel.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 06-10-2009, 02:46 AM
im pretty sure its not the gas but ill check the wiring harness as for the ASD relay where is it located?
Old 06-14-2009, 09:46 PM
ok i got the wrong year its a 1997 with a 3.8lt engine, it has a factory alame installed but its still having the same problem. any help would be great. thanks.
Old 06-18-2009, 12:02 AM
Is the ck engine lite on? If it is, pull codes and post. If you don't have any codes, then you could have cam or crank sensor out of sync. You will need more information to post to help you.
__________________
Old 06-18-2009, 12:32 AM
cyclone429 cyclone429 is offline
Vehicle: 06 2500 SLT Ram 2500 4x4 6sp hemi
Shot in the dark here.. It could be your main fuse panel.. Its made out of plastic and once is shot, you need a new one.. the fuses are not sitting in the contacts, because the contatcs are moving...
Old 06-18-2009, 04:31 AM
no check engine light but where are those sensers located so i can check them and as for the fuses ill check those to.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
