DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-15-2009, 09:35 PM
accesslimo accesslimo is offline
Angry 2001 Town and Country A/C problem
here is what i know. refrig level ok, fuses and relay ok, no power to plug at compressor, either wire. What am i missing. cant find a scematic anywhere. Also, the blowes,both front and rear, only work on high. i pulled the switch panel out and back probed all the wires to see if any changed with the switch being turned on or off, nothing changed. Does the switch send a neg. signal? ANY HELP WOULD BE GREAT!!!!!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-15-2009, 10:01 PM
Also...i tried jumping the plug on the acc...it didnt turn on the clutch and it bogged the van down/????
Old 06-30-2009, 08:47 AM
George Rhude George Rhude is offline
Vehicle: 2001 Caravan, Nissan Frontier, Suzuki Cavalcade
Normally the fans only working on high is caused by the blower resistor located in the heating duct being defective. This is accessed by removing the glove compartment. I went to NAPA to get my new resistor. Good luck, George
Old 06-30-2009, 04:20 PM
kev2 kev2 is offline
I cannot attach the schmatic....my bad.....is this manual or automatic climate control ?
fuse 18 good? at a/c relay remove relay use dvom probe termnal 30 AND 86 CAVITY BOTH SHOULD BE 12V?
only high speed blower is this a new issue or system worked before with HI only?
how do you know that the refridgerant pressure is adaquate?
ALWAYS use gauges for A/C work both HIGH and low!!
STOP jumping A/C switches...
suggestions:
post the static pressure* PCM must see correct tranducer reading ... check for codes both CEL and Heater A/C controler..... there are directions in owners manual....
*There is a minimun press requirement
Tags
2000, 2001, ac, climate, clutch, compressor, control, country, instructions, issues, located, pressures, relay, replacement, town, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
