DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-25-2009, 04:51 PM
chimeraxp chimeraxp is offline
Default no a/c front front vents
hi , I hope someone can give some ensite on our problem , .
I just went out and topped up the a/c using a kit .
now the gauge barely moved in to the blue (the kit says blue is charged)
so during testing I notice that the van only blow cold air while the setting is on defrost or floor and defrost . is this normal ?
I though is temperature setting was to cold then it would blow a/c air on all settings .
I noticed that the van does not have a max a/c or a/c switch don't know if that makes a difference or not .
using a temperature gauge it shows 49F is this good temp ? this is our first van with a/c so we don't know that much.
thanks for any help you may be able to give me
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-26-2009, 10:44 AM
vabear vabear is offline
Vehicle: 1996 Dodge Caravan, 1998 Dodge Neon, 2007 Hyundai Sonata
Default AC
You should see in the normal mode, +45 -+50 F at the center vents at idle and +40 F at 1500 RPM or greater. Also when the system is at full charge the manifold gauge should read in the 35 psi to 40 psi range. If no air from center vents i would suspect the air distribution motor is not opening the flapper valve for that vent.
Old 06-27-2009, 11:53 AM
Thanks for the info ,
I do get air from the center and front vents , but it's not cold air , it's warm air .
Tags
ac, car, charger, coming, defrost, dodge, front, max, normal, ram, switching, temperature, van, vent, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
