DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 07-01-2009, 11:46 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3 DOHCgarrett t3 is offline
Vehicle: 98 RT Neon Sedan
Send a message via Yahoo to DOHCgarrett t3
Default Trans type 99 Dodge caravan: Base model.
I have been doing a bit of searching and I can not seem to find the trans type of a 99 dodge caravan base trim 2.4
3-speed 31TH automatic
3-speed A670 automatic
these are the 2 types of 3- speeds that I have found here http://en.wikipedia.org/wiki/Dodge_Caravan#Engines_3 Where would I look to be sure and if anyone know what vin code didgit it would be and what digets indicate the trans type???
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Iceman CAI, 55mm TB, P&P intake, Indy head w/1mm oversized Valves, Crane 14 cams, Pacesetter headder, OBX LSD, Unorthodox UDP, Solid bobble strut. solid front motor mount. prothane motor mounts. Battery in trunk, KYB-gr2 w/Eibach Sportline Springs, Eibach Sway Bars, Every bushing replaced with Prothane bushings.
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-02-2009, 12:13 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
A670 is the same as a 31TH,as is a604 is a 41TE.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 07-02-2009, 12:48 AM
what diffrences give the nomenclature to both the 31TH and the A670 becides the numbers?
__________________
Old 07-02-2009, 01:13 AM
This may sound like a history lesson. From the time the 3 speed transmission it was called a A670 auto trans, until 1995. Thats when chrysler change the numbers, because of the A604 trans.So now you have the 31TH. A604 41TE and when there was the 904, 999 became 42/44 RE or RH, 46RE or 46RH. The reason of the number change, because nobody wanted to buy a mini van with the A604 trans. Hope this helps you in some way. If not you can always send a pm. I am a factory trained trans tech.
__________________
Tags
31th, 99, a670, caravan, caravans, dodge, front, manual, photos, repair, replace, spd, struts, transmission, types
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
