DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 07-06-2009, 02:21 PM
lebstyle lebstyle is offline
Default 2006 Caravan Park Reverse Issue
Hi All I have a 2006 Dodge Caravan SXT, Whenever I shift the vehicle in park, it goes into park,but on the dash it says it is in Reverse, and the back reverse lights stay on. It is always doing this. the battery draisn quite often, I am not sure if it draining due to this problem.
any help is appreciated, \
thanks in advance
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-06-2009, 03:56 PM
kev2 kev2 is offline
Anything to add?
CEL- is it on?
recient repairs, modifications, accident?
If nothing above applies,
remove key put in pocket
parking brake on
  1. Park the vehicle on level ground and apply the parking brake.
  2. Place the gearshift lever in gated park (P) and remove ignition key.
  3. Loosen the cable adjustment screw at the transmission manual valve lever.
  4. Pull the gearshift lever fully forward to the park position.
  5. Release the park brake, and rock the vehicle to make sure it is in park. Reset the park brake.
  6. Tighten the cable adjustment screw to 70 in. lbs. (8 Nm). Gearshift cable should now be properly adjusted.
  7. Make sure the vehicle can only be started in Park and Neutral.
Old 07-06-2009, 04:01 PM
No CEL is on, When it first started hapenning, the whole prnd321 wasnt marking properly, I removed the IOD Fuse and reset the battery, then i noticed when you put it in park, it shows it in reverse, so the reverse lights are on, and you cant open the rear gate b/c it thinks the van is in gear.
Any more info, please let me know
Old 07-06-2009, 04:07 PM
I would like to add, that when it is in park and shows reverse, that it is in actual park, it wont move.
Old 07-06-2009, 06:37 PM
confusing " No CEL is on, "
cablle would be step 1,
next would be check trans range sensor.....
Old 07-07-2009, 12:34 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
A shifter code will not cause the ck engine lite to come on. There is a test for the shifter error code, but you will need a DRB scanner. The problem could be a TRS or the prndl circuit board. Try unplugging the TRS connector with the key off and plug it back into the sensor. you may have a bad contact.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 07-07-2009, 02:52 PM
Where is the TRS Sensor Connector? I willl try to do that and see if it solves the problem. when I first got the van it was messing up alot on the PRND Screen, it wasnt marking right, but after I took the IOD Fuse Out and back in and reset the battery,, it went back to normal except for the P and R Mishap.
Old 07-07-2009, 10:30 PM
The TRS connector is below the output sensor, Should be 8 wires going into the connector.
__________________
Tags
2007, brakes, caravan, computer, dodge, light, lights, lit, park, prndl, reverse, reverse4, shows, stay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
