At least on my Caravan, when you turn the key on, not starting the engine, you should hear the fuel pump run for just under 1 second and then shut off. If you are not hearing that, obviously the fuel pump is not coming on.
Is there a fuel pump relay reset on the Caravans of this year? I've never had mine trip out. I think it may only be a Ford thing. It's one of those things that shuts off the fuel pump in case of accident or rollover. I know I tripped mine on my 91 Escort just changing the oil. Luckily the Ford salesman had told me about it since they had so many Fords coming back to the shop under warranty that had it tripped.
__________________
91 Caravan 3.0 151k
