DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 07-10-2009, 02:25 AM
kevals kevals is offline
Question 97 Caravan 3.0L A/C Questions
I have the 97 Caravan 3.0L car.
Doing some A/C work and wanted to know if someone can give me genaral info on what pressure I should be seeing on the low side and on the high side once I have proper amount of 134A in the system.
The A/C was working fine, but lately has lost the coldness, and I figure it needed a recharge.
It took a long time for it to get to this condition. It seemed to have leaked out through fittings on low/hi side so I replaced the o rings. Now, wanted to know what pressure I should see on the gauges on low and hi sides during A/C operation. The outside temp out here at this time of the year is about 95-100F during the day, around 90 in the evening (around 6pm).
After I put some in, I think the low side was reading about 45psi, and hi side was around 200-210psi. I read in other places that these numbers are low for both low and hi sides.
Really appreciate it. Thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-10-2009, 03:05 PM
kev2 kev2 is offline
You replaced some O rings?
SO the system was open to atomsphere .....?
AFTER you used the proper equiptment to recover the refridgerant you forgot to add...
If yes then you will need to evacuate the system- pull a vacuum - checking that is holds.
Ball park. Rule of thumb, quick and easy
when the charge is NOT weighed in.
low side @35-40 high side(ambient X 2.5.) will be high end of expectation
Alsolet us know front only or front and rear
Old 07-10-2009, 04:34 PM
skipped a few steps for simplicity reasons.
to make things easy skipped the part where I replaced compressor, dryer, expansion valve, etc. For obvious reasons, when I got in there, there was nothing to 'capture'.
Now, that is a lot of explaining....lol.
Yes, evacuated system and yes it holds.
It is a front A/C only...no rear.
when you say hi side = ambient x 2.5, are you talking 2.5 x of what the low is?
Ambient pressure is 14.7psi at sea level, and I am pretty positive you are not talking about that ambient. Basically, it is 2.5 times of what ... If you could fill me in, I would appreciate it.
Old 07-11-2009, 08:39 AM
.......ambient temp.. ie 80* day high should be @ 200psi
system was then empt how much have you put in?
my info says 34oz.
type amt
All Eng. w/ Front AC Only .................................................. ................
R-134a 34.00
Old 07-17-2009, 08:02 PM
... awesome...2.5x ambient temp (F) on the high side, and 35-40 on the low side (high end of the scale as you say).
we have been having temps of 105 for a long spell.
Looks like I need more 134a - I put in about 28oz.
Thanks for your help. Will try to do this in the next couple days - being sick to day.
Thank you.
Old 07-17-2009, 09:47 PM
Ram15002ndGen's Avatar
Ram15002ndGen Ram15002ndGen is offline
Hey guys, don't mean to crash your space but for temps between 90-100 you should be looking at 25-43 on the low, and 165 to 270 on the high for R134a Freon. Make sure you have a gauge manifold that you can check both sides. The cheapy low side gauges are crap. I know the range cause I just checked mine the other day. BTW I hope you evacuated and held the vacuum for at least 60 minutes at 30psi. You don't want to leave any moisture in there.
__________________
1997 1500, 318 CID, 4x2 Laramie SLT, Extended cab, Pendaliner SR bed liner, After market fogs in OE slots, Bone stock, Dodge Mud Guards, Custom tool box under hood on pass fender, Laramie Club Member, Black Truck Club Member 111.
Tags
1998, 30l, 93, 97, ac, caravan, compressor, high, low, orings, pressure, side, valve, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
