DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 07-13-2009, 04:47 PM
vabear vabear is offline
Vehicle: 1996 Dodge Caravan, 1998 Dodge Neon, 2007 Hyundai Sonata
Default PCV Hose Replacement
I have to replace the PCV hose (the hose from valve cover to the PCV valve) as the old hose is toast. This is on a '96 Caravan with 3.3 V6. I have the hose but the area to work in is behind the plenum so I guess I am working in the dark. Any tips, should I remove the wiper motor tub, all responses gratefully accepted.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-13-2009, 07:21 PM
RickMN RickMN is offline
I would remove the wiper tub before I'd remove the plenum. At first glance the plenum appears easy. But there are a bunch of support brackets on the rear end of it and they are a B___ch to get at. Change spark plugs on the rear bank while you have the tub off.
__________________
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology. Visit my blog for over 400 fix-t article, tech tips, TSB's, and wiring diagrams: www.ricksfreeautorepairadvice.com
Old 07-13-2009, 08:57 PM
Default PCV Hose
Thanks for the response. I did the plugs and wires last year and took the tub out for that repair, but, I never thought about the PCV having a hose off of the rear valve cover (I was familiar with the clean air hose off of front valve cover) and when I discovered the hidden hose that was fried, it amazed me, plus they hid it in an almost impossible spot to get at ( and I thought my 1988 BMW 750il was bad). I guess a tub removal is in order.
Old 07-14-2009, 12:09 PM
Default PCV Hose
The secret is not the tub, but the coil pack, once that is off you can touch the end of the hose at it enters the valve cover.
Tags
1998, 98, avenger, caravan, dodge, hose, hoses, intrepid, neon, pcv, plenum, pvc, replace, replacement, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
