My van feels like running on 4 cylynder after driving on heavy rain on the highway,so i check and remove the plug wire one at a time while the engine is running and #1 no spark.Do i have to replace the ignition coil.the engine light came on but i didnt get any code. thax
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
im checking the coil,the wire i just replace them recently and try different wire but still no spark coming out from the coil #1,and i check the secondary resistance on the coil 3-6 1-4 5-2 no reading on 1-4 but the rest are okey .
if you ohm'ed th coil and 1-4 is open the coil is bad.
Now why did you change coil?
if for routine maintance return and get a OEM product using the old one meantime...
If you changed for a failure of 1-4 coil...
post all codes you have.
vehicle is STOCK no modifications...
secondary ign is QUALITY - no "gimicks" first suspect in coil failure secondary "load"
