DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 07-24-2009, 01:16 PM
lacaravan lacaravan is offline
Vehicle: 2000 Dodge Caravan
Default popping fuses? 2000 Caravan...
I recently had the limp mode fiasco 100 miles from home. I now have a fuse problem. I have two fuses that keep popping, the panel illumination fuse under dash, entire guage panel in the dark, and the memory IOD fuse under the hood. Both are #10 fuses.
I checked all wiring and no battery corrosion, frayed wires or broken ground straps....
I unhooked battery overnight, checked everything out that I could think of and ordered a Equus 3130 obdII scanner awaiting it for my tool box.
Have owned the van for about 6 years, maintance has been kept up on it and I have 250,000 miles on it and would like to finish it to 300,000. Transmission was replaced at 150,000 by previous owner, changed both speed sensors two days ago. I drove it about 5 miles after replacing the sensors and it went back into limp mode on the 5th mile. I have ordered a solenoid pack and will be changing that soon, fluid and filter changed and looked good.
Could the solenoid pack be causing the fuses to pop?
Thanks for any help.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-26-2009, 10:18 AM
chopper chopper is offline
I wouldn't think so.
The fuse problem is almost surely an intermittent short to ground that's going to be hard to find.
This link is to a short circuit detector.I've never used one but I've heard that they do work so maybe this'll help.
http://www.jcwhitney.com/Battery-Ele.../600016355.jcw
__________________
92 Dodge Caravan 3.3 07 TC 3.8, 04 Mustang GT three Harleys and an airplane.Buy American!!!
Old 07-26-2009, 03:22 PM
kev2 kev2 is offline
any chance you have the fuse #s ie. blown FUSE #11 in PDC- 10Amps?
my diagram uses numbers not items to label pdc.
Also remote starter or other aftermarket electrics?
Always got to ask....CEL on any codes?
Old 07-26-2009, 04:02 PM
Update...
I got a hold of a scanner and I have two codes:
500 -- Speed sensor (brand new sensor)
1698 -- no messages received from trans. control module
no aftermarkets installed all factory.
Tags
03, 12, 1997, 2000, 98, blowing, blows, caravan, dodge, fuse, fuses, illumination, iod, neon, popping, scanner, srt, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
