DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 07-26-2009, 12:10 AM
marshallguy marshallguy is offline
Default Issue with veh starting and 2nd possible related issue, more in comments
00 Dodge Grand Caravan, issue with vehicle starting and it slows while in drive then pops back to normal.?
I have a 00 Dodge Grand Caravan SE 3.3L
Problem: Today I went to start it and it wouldn't turn over, tried second time nothing, finally third time it started. When I turned the key the first two times there was no sound just sounded like battery was dead. Second issue to go along with the first as I think it may relate is that when I was driving down the road today, about half a block from my home the vehicle then seemed like it dropped in speed real quick. It seemed like it went from 25mph to 15mph all at once, but it was still at 25mph, then all of a sudden it just popped back into normal speed. Now im not a mechanic obviously, but my signs would say ALTERNATOR for first issue, not sure if same for 2nd.
Thanks in advance for any help... Dustin
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-26-2009, 09:50 AM
vabear vabear is offline
Vehicle: 1996 Dodge Caravan, 1998 Dodge Neon, 2007 Hyundai Sonata
Default Issues
If the alternator was going south I would expect a battery light ICON and maybe a electrical whine from the engine compartment. I would first take off the battery cables from the battery, clean both the posts and terminals and maybe lube the area with white Vaseline or buy some of the felt donuts at a parts store to go over the battery post and under the cable.
Old 07-26-2009, 10:10 AM
chopper chopper is offline
The non-starting/cranking problem might be the ignition switch failing.
The abrupt slowdown could be the dreaded "limp mode". This is what the transmission does when there's a problem to keep from destroying itself and to make sure the driver doesn't ignore the problem.
Here's a link that can help.
http://www.allpar.com/fix/trans.html
__________________
92 Dodge Caravan 3.3 07 TC 3.8, 04 Mustang GT three Harleys and an airplane.Buy American!!!
Old 07-28-2009, 12:55 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
From 1996 thru 2000 minivans, there has been an ignition switch problem not only for starting , but also for a transmission loosing power at the tcm. causing limp in.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
