on this van when you swith the vents from floor to def to vents it uses vacuum. I noticed when using AC that when I accelerate, not even really hard just like climbing a hill on freeway it acts like it looses vacuum and switches down to floor as soon as I let off accelerator it switches back to vent. Is there a Vacuum can like some of the other vehicles have to store vacuum?? if so where? I cannot find anything like that in schematics. I cannot find a vacuum leak anywhere. does anyone elses do that or is mine having an issue I had a Jeep that did that but my vac can broke(plastic ball) and i had to bypass it so I imagine it had no stored vacuum.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Easiest way to trouble shoot this is to use a hand-held vacuum pump and attach the hose directly to the vacuum motor that controls the air "mode." Apply vacuum and see if the vacuum motor holds the vacuum. If it does, then you'll have to test the vacuum line from the switch to the motor. Work your way backwards until you find the component that leaks.
__________________
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology. Visit my blog for over 400 fix-t article, tech tips, TSB's, and wiring diagrams: www.ricksfreeautorepairadvice.com
You need to replace the vacuum ck valve to a larger valve. There was a TSB for this back in the day.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
TSB 24-06-92 and mopar part number 4677204 vacuum valve. Hope this helps you.
__________________
oh thatks can I just go to a dodge dealer and get that or will I have to buy it? is it the one that connects to the vacuum tube on the break booster? i see what looks like a ck valve there
You may to ck to see if its in stock and how much.
__________________
ok what I was wondering is I got a paper from the dodge dealer here in town about something to do with the wiper bushing and it is covered by dodge all i need to do is bring the van in I have to pay nothing I was wondering if that vacuum thing was one of those also.
That maybe wiper recall 836. and no thats not part of the wiper.
__________________
I musta mis read it I was sure it was a recall for some bushing on the wiper arm maybe it was something else. I just thought that maybe the vacuum ck valve was a free fix like the other one.
