DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 08-02-2009, 07:24 PM
tobytigger tobytigger is offline
Default 99 GC clunking noise front end
How do I tell if the front sway bar links are bad in a '99 GC with 130k? There is a clunking noise coming from both sides that usually occurs at low speeds while backing out of a parking space, etc. Based on what I read here, the sway bars are vertically mounted. I can rotate both bars with a wrench with the car on the ground. Are these difficult to replace?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-03-2009, 10:55 AM
MartymanVR6 MartymanVR6 is offline
Vehicle: Vw Golf GTI VR6
hold the sway bar near the link kit n move it up n down if it makes some noise change em both.............easy to change a ratchet n pair of vise grips to squeeze the lil rubber boot preventing it from turning.....
Old 08-05-2009, 03:43 PM
Are you referring to grabbing the long horizontal sway bar and move it up and down to see if the vertical link moves? On a '99, looks like the passenger side is easy to change but drivers side link bolt on the bottom is in a tough spot? Any idea if I should be able to access if I put the car on jacks? Thanks Marty for the help.
Old 08-08-2009, 03:52 AM
Sometimes there stuck tight in rust and crap....but with a ratcheting key and a good pair of vise grip to squeeze where the rubber boot is......replace the vise grip tighter as it goes.........
If you have access to an impact gun and the good swivel socket you will save time..........Heating them up is good too if possible.....
To check if its loose you hold the sway bar where: the lower part of the link kit attaches and move it up n down........ youll feel the loose for sure
Tags
06, clunk, clunking, dakota, dodge, end, front, intrepid, low, neon, noise, ratcheting, sound, speeds, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
