Error code P0456
Old 08-28-2009, 04:37 PM
BigBlueGa's Avatar
BigBlueGa
BigBlueGa is offline
Default Error code P0456
'03 Caravan 83k miles. The engine light came on and this is the code P0456 that was on it. Where would be good place to start looking for the problem?
Old 08-28-2009, 05:21 PM
kev2's Avatar
kev2
kev2 is offline
p0456
Evaporative Emission Control System Leak Detected (very small leak)
SIMPLE
this is an evap system code- often called -loose gas cap- As starting with gas cap is first suggestion....be sure its tight, and the seal is good..
I would ck that ....fill tank operate hopefully cap was issue and repeated drive cycles will clear code....
If dosn't clear:
no other codes.... then let us know the -the EELD - evap emiss leak detector (smoke machne) is next step BUT is vehicle operated on steep grades? there is a TSB FOR a problem with PCM
Old 08-31-2009, 09:31 AM
BigBlueGa's Avatar
BigBlueGa
Thanks for the info, away from the computer all weekend. Will try the gas cap and see what happens. The van is not driven anywhere that has alot of steep grades.
Old 08-31-2009, 10:02 AM
jarhead03's Avatar
jarhead03
jarhead03 is offline
Check your rubber hoses underneath by your gas tank, mine had dryrotted and threw that same code
Old 08-31-2009, 11:09 AM
RickMN's Avatar
RickMN
RickMN is offline
Most common causes of trouble code P0456
http://www.ricksfreeautorepairadvice...ysler-vehicles
How to test a leak detection pump
http://www.ricksfreeautorepairadvice...edit&post=2122
How the whole EVAP system works on a Chrysler vehicle
http://www.ricksfreeautorepairadvice...=edit&post=544
Old 01-23-2012, 11:41 PM
mark1963's Avatar
mark1963
mark1963 is offline
it was a LOCKING GAS CAP ON MY RAM 1500, if you installed a locking gas cap, even if bought from the dealer as where i bought mine, try the factory cap first,
Old 01-23-2012, 11:49 PM
otgarzà's Avatar
otgarzà
otgarzà is offline
456, 441, 442, 440...had all of these and i switched out the gas cap to realize it wasnt the prob. then changed the evap hoses under the truck...fixed two codes. the other two went away after i replaced the evap hoses in the engine. Ive been code free for about two months and hoping to keep it that way...ive got emissions this year.
Old 05-25-2012, 07:03 PM
dodgeman7's Avatar
dodgeman7
dodgeman7 is offline
I know this is an old post but I fixed my small evap leak. My engine light came on last week and came up the code P0456 on my '03 Grand Caravan. Checked the obvious locations connectors, hoses near air filter. Found that my pcv valve was loose and tightened it and cleared the codes again. After a very short drive down the street the check engine light came on again. Traced all evap hoses to the vapor canister under the van and pulled off one 3/8 hose off the canister only to find out that the hose split near the connector. Bought a regular 3/8 fuel hose and cut it to length and put new clamps on and slightly tightened them up. I then cleared the codes again and drove the car about 2 miles and no problems with the check engine light. Hooked up OBDII to recheck for any codes and found nothing. Seems to be all okay now. Very simple to fix even a monkey can do it.
Here is what the vapor canister on a GC looks like. It's located on the driver's side under the car. It's big and you can't miss it!!!
http://www.rockauto.com/catalog/moreinfo.php?pk=932968
Old 08-21-2014, 10:51 PM
Tony Back's Avatar
Tony Back
Tony Back is offline
Error Code: P0456 Fault:
Evaporative Emission (EVAP) System - Small Leak Detected
Possible Cause:
Malfunction Indicator Lamp (MIL)(K83) active.
Fuel Cap not fully attached.
Evaporative Emission (EVAP) System leaking/faulty.
Evaporative emission (EVAP) pressure sensor.
Possible Solutions:
Check Fuel Cap.
Check Evaporative Emission (EVAP) System.
Quick Reply: Error code P0456
