Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
i just had the trans replaced a week ago and i drove it for the first time this weekend. about 200 miles and all was good. today i was doing some other work on it that had nothing to do with any electronics and went to move it after and the light came on. i read the codes, AC/Cluch Relar Mil code 033, P1698 No Trans CCD Messages Mil Code 066, No Body CCD mil code 066, and P0600 Serial Comm Link Malfunction. now i know the code (No Body CCD mil code 066) is just a duplicate of the trans code because its the same mil code, but i never had the relay in for the ac clutch and it never came on and what about the other codes??????
PLAEASE HELP ASAP NEED TO BE INSPECTED
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
"How are you getting these codes- key trick, scanner, reader?"
Im using the Actron CP9185 Scanner
"reason I donot think p0033 is a/c ...
Am I wrong you have p0033, p0066, p0600, p1698..."
I didnt say p0033, p0066, Mil code 033, P1698 No Trans CCD Messages Mil Code 066, No Body CCD mil code 066, and P0600 Serial Comm Link Malfunction a mill code isnt the same as the p---- codes
"What were you doing -repairs- exactly what was trans issue and repair?"
Trans only had 1st and 2nd and didnt shift well between them. The tranny fluid was filled with shavings. The repair was a tranny from a junkyard and it works perfectly, shifts fine, Everything works perfect just the codes in the computer.
"remote starter on vehicle?"
No remote starter
"first time driving after trans R&R?
Yes it is but i drove it for 200 miles or more before the light ever came on.
" back to the shop esp the p0600 and the p1698 you paid make it their problem"
Those codes arent tranny codes them self. they are to do with the electrical system. he didnt do much of anything to it.
You may have one of the modules taking the bus down,or the ignition switch is causing a problem with the TCM. Thats how the TCM gets its power feed. If you need a pdf file i do have them.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
sure that would help alot. thankyou. do you think it could be a grounding issue? or a issue with one of the sensors on the tranny? or even the wire harness on the tranny? or would it be a different code. what kind of testing can i do?
