DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 09-02-2009, 01:39 AM
sunpack sunpack is offline
Default 2002 Dodge Caravan. No Horn, Airbag Light but cruise works
Ok so this is driving me nuts. I dont have a scanner to scan the SRS codes but the symptoms pointed to possibly the clock spring. The cruise control works but the horn does not and the airbag light is on. I changed the clock spring with a new one from Dodge but I still have the problem. I am going to start tracing for power on the horn wire but since the horn, airbag and cruise contral go through the clock spring I am thinking it is unusual that a bad wire for the horn would throw out the airbag. Thinking something else here. Does anyone have the wire diagram for a 2002 Dodge Caravan. Also has anyone experienced this problem?
Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-09-2009, 01:02 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
Its helps to have a scanner, because everyone will be just guessing. You could have an open circuit (fuse) or wire. Start by checking the fuses and get a scanner. Air bag fuses are in the yellow holders, you may have two of them. and ck the fuse for the horn too. To ck the fuses you will need a 12 volt test lite or a DVOM. This is a must, just looking at fuses won't show you if the fuses are good. Also when did the problem start or what mods were made?
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 09-09-2009, 10:31 AM
Default Corrosion in fuse box - Dodge Caravan
Thanks Master Tech. So i figured out the problem and I think I would advise anyone with a Dodge Caravan to do the same. I started tracing for horn power and realized that there was no power from the fuse box, however the fuse was good. I then noticed a bit of corrosion on the leads that go into the fuse box (on the underside). So I removed the fuse box and started to clean the leads. I then noticed that the pins on the fuse box itself was corroded so I removed the top have of the fuse box to reveal the pins. A few of the pins (including the horn) was corroded to the point that a few of the pins had broken off. This is why the horn did not work and also there where a few other components that where acting strange. I found a fuse box at a junk yard for $100 (dealer $800). However before I replaced the fuse box, I opened the new one (junk yard) cleaned the corrosion that was already starting, sprayed a light coat of rush inhibitor on the pins and closed the box. Van runs fine. Talking to a few mechanics, this fuse box corrosion is a common problem on the caravan. So now, once a year I plan to remove the fuse box, check and clean corrosion and reapply the rush inhibitor.
Old 09-27-2009, 04:30 PM
JoelPB JoelPB is offline
Default Airbag light
You can check continuity through the airbag clockspring fairly easily. Remove airbag (plug under airbag) and test from connectors going into clockspring to those coming out that airbag wires plugged into. I was told my clockspring was absolutely the problem, but then I checked and the advice was just the usual BS.
Tags
1995, 2002, airbag, block, box, caravan, clean, corroded, corrosion, cruise, dodge, fuse, horn, intrepid, ramcharger, srs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
