DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 09-02-2009, 06:05 PM
tomshanty tomshanty is offline
Default white smoke near exhaust manifold (radiator side)
Hi, I have a 1999 Dodge Caravan 6 cyl with 144056 miles. When I start it up, it runs fine. But after a few minutes, I see white smoke around the exhaust manifold (radiator side). This engine is pretty filthy with oil, grease, and whatever else. So I can only hope that this smoke is a result of the engine just burning up the oil, grease, etc. I thought it might be coming from the spark plugs, but it's not. Does this sound about right? Is the engine just burning up what's on it?
By the way, this van has been sitting for a while. And I recently replaced the timing belt, water pump, and oil pan. I don't know if this could be related to the engine smoke.
Thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-18-2009, 10:10 PM
clipper77 clipper77 is offline
Vehicle: 96 ram 2500 8L v10
I have that same problem with my 96 v10. I recently did the gaskets in my upper and low intake manifold, along with valve cove gaskets. I initially thought it was oil leaking onto the manifold but it looks like its coming from where the two pipes meet. I have no clue what it is maybe someone on this forum does....
Old 09-18-2009, 11:23 PM
22dodge 22dodge is offline
Vehicle: Dodge
since you say timing belt that means you have a 3.0. these are notorious for leaky valve covers and cam seals and cam plugs. you MUST get this fixed. leaking oil on hot exhaust manifold can = FIRE!!!
Old 09-19-2009, 06:37 PM
Thanks for the responses.
22dodge, this is my brother's van that I've been working on and he has it now. In regards to the white smoke that I saw, it stopped. I will double check for leaks. Is it possible that the smoke was from oil that got onto the manifold while I was changing the oil pan? I will double check regardless. And thanks again.
Old 09-19-2009, 07:03 PM
Vehicle: Dodge
well, oil runs down hill. oil pan is below exhaust so what do you think. now that you add more to the real story, any chance you are a sloppy oil pourer? it's amazing how long the oil will smoke off the manifolds even @ a couple tsp.
Old 09-22-2009, 09:29 PM
Touche. I was thinking that maybe while I was changing replacing the oil pan, I got oil on the exhaust . I used a funnel when filling the oil so I don't think that's the cause. I will get the van back from my brother and check the valve covers.
-thomas-
Tags
1995, 95, avenger, coming, dakota, dodge, engine, exhaust, harley, manifold, radiator, side, smoke, smoking, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
