DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 09-23-2009, 09:43 AM
abort_retry abort_retry is offline
Default Wheel Bearing Hub 14" or 15/16"?
hi, i have a 1996 GC 2.4L. i have a humming sound possibly on the rear and it gets louder as speed increases. i suspect the wheel bearings are about to go. i am not sure what wheel bearing hub part to buy. can someone help me out decode what option my van have? i can provide my VIN.... thanks...
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-23-2009, 12:05 PM
22dodge 22dodge is offline
Vehicle: Dodge
Quote:
why?
You just go to an autoparts store, tell them year, make, model, engine, wheel size and BAM they give you the part for you vehicle (usually 95% right)
if you have ABS then you'll need an ABS hub. if not, you could use either ABS or NON abs bearing assembly.
Any gen3 van with the 14" 100mm bolt pattern will work.
Old 09-23-2009, 12:12 PM
thanks... i am overseas so no competent chrysler parts store other than the dealerships. i will be buying from ebay or rockauto. rockauto have the 14" and 15". but im not sure which one is for my van. btw my van has the abs on all hubs front and rear.... i bought it with an aftermarket wheels. i think the bolt pattern is 5x114.3 because i can fit a mazda 3 wheels on it.... does it mean that 14" have the 5x100 and 15"/16" have the 5x114.3 bolt patterns?
Old 09-23-2009, 04:41 PM
vabear vabear is offline
Vehicle: 1996 Dodge Caravan, 1998 Dodge Neon, 2007 Hyundai Sonata
Well the tire size is a giveaway (14/15/16) and on our cars it is a hub bearing assembly (one piece). I had this issue on my 96 Caravan and thought it was the right front, bought that assembly and ity turned out to be the left front (well if one was going bad, the other was probably not fr behind) I now have two new assemblies and no more noise.
Old 09-23-2009, 05:37 PM
Vehicle: Dodge
Quote:
14" wheels are 100mm and 15/16" wheels are all 114.3mm 4½"
so you just need to measure your bolt pattern to be sure however all 2.4's and 3.0's, that I've ever had, were only 100mm 14" on gen 3. 3.3 and 3.8 only used 4½" (gen3)
As for which one to replace... I've mis interpreted which side. I put in a new bearing and still had the noise, so I took the used bearing I just replaced and put it on the other side... took care of the noise and only had to buy 1 new assembly. Fortunately they only take a few minutes to change out.
Old 09-24-2009, 06:28 AM
i tooked it to a tire shop and indeed the bolt pattern is 5x114.3. the door sticker on the driver side indicated 15" tire pressure. on the glove compartment, the standard tire size is 215/65/15. so i guess the hub assembly on my van is for 15/16".... do you think the timken brand at rockauto is a good quality hub bearing? what about those sold on ebay that goes below $50 each? thanks...
Old 09-24-2009, 11:36 AM
Default Wheel Bearing/Hub
TIMKEN is a good brand.
Tags
1998, bearing, bearings, bolt, caravan, dodge, hubs, part, pattern, problems, put, size, to, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
