I just bought a 2009 Caravan, Dodge says it can handle either 16 or 17" tires.
I'll be needing a set of snow tires and I was told that to save a bit of money I could put on 15" snow tires.
Is there any problems/issues with putting on 15" winter tires ? or should I stick to 16" winter tires ?
thanks !
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
thanks for your reply,I was thinking along the same lines...
Aside from trying to find 15" rims that will fit the van, I was thinking that the insurance could give me problems in case of an accident and they find out the van had 15" tires. (smaller tires then what the manufacturer recommends) I guess I should call the insurance myself, just out of curriosity.
Other then that, does the van really care if it's got 15" tires ?
regards,
Richard
did you ever think that changing the size of the tire would effect other things like transmission shifting and speedometer?
seems you need to refresh some basic math. if you change the size of the tire, you effect the number of revolutions per mile which will effect the speedometer reading.
with smaller wheels, be careful of them hitting steering or suspension pieces.
i'd stick with the same size. the little bit of $ savings on smaller tires aren't worth the hassle of speedometer problems, wheel fit, etc.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
I have 15 inch rims and snow tires left from my 05 Grand Caravan. When I bought the 09 earlier this year, the salesperson swore up and down that they would fit on the 09. The only reason this came up was because it was January when we were doing the deal, and I mentioned I needed to get the snows off the old van. I wish I had taken him up on the offer then to swap the snows off the old and put them on the new van. I might have been able to play off his mistake and get a deal on a new set of snows, which I am now finding to be a real pain to get.
