DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 10-18-2009, 11:27 PM
AFMarksman AFMarksman is offline
Default 05 Caravan 2.2L P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
I'm in the Air Force an deployed overseas. My wife is back in Tucson with our Caravan. She got the check engine light and a few minutes later the van started running rough. She called a friend of ours to help. He took the van to Autozone and they ran the code. It was P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT. He replaced the sensor and the van ran fine for about another 20 minutes and gave her the same problems again. What should I do? Thanks!
Dave
2005 Caravan 2.2L
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-18-2009, 11:29 PM
Quote:
Originally Posted by AFMarksman View Post
I'm in the Air Force and deployed overseas. My wife is back in Tucson with our Caravan. She got the check engine light and a few minutes later the van started running rough. She called a friend of ours to help. He took the van to Autozone and they ran the code. It was P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT. He replaced the sensor and the van ran fine for about another 20 minutes and gave her the same problems again. What should I do? Thanks!
Dave
2005 Caravan 2.2L
ETA for spelling
Old 10-19-2009, 11:02 PM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
Hi Dave.You may need to take the van to a repair shop and have the transmission removed. Thats because the flex plate cracks causing the windows for the crank sensor not to line up....... misalignment code,or the new sensor you brought is defectived.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 10-20-2009, 09:42 AM
92dak5.24x4 92dak5.24x4 is offline
i read that if you want to be sure it's a bad flex plate and find after pulling the trans that it wasn't. it was posted to use a dual trace oscilliscope, if the patterns don't line up, much better chance it's indeed broken. as stated the sensor you bought is defective, but if you had the problem before replacing the sensor, odds are not a sensor issue, but yes many people have had numerous bad sensors in a row but thats the rare exception.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
