- my caravan 93 stalls sometimes when I'm going out from parking or when I'm going out from my house .
- the Codes: consult an specialist to switch the codes and read them, so the codes List will tell you what they mean.
- the Codes told in my caravan: Cables, Hoses about air and something... (it depends your codes).
- We checked the hoses and one of them (about the air comperssion) was bad , after repair the stalling was less.. and the engine sounds better.
- We will replace the distribution cables (it's recommended because in my caravan, we use it daily with passengers and after one year or more, it's recommended and the codes mean soemething about.)
- iF your caravan stalls in Corners and loses power till turns-off, probably the component in charge to maintain the revolutions in low speeds even in slow speeds when you turn in cornes its failling, it is not maintaining the enough revolutions in slow.
that's my opinion and self- experienced issue.
