2002 Caravan on start-up, the electric windows, blower fan and wipers will not operate. Sometimes they work after a few minutes, other times not. I have checked the grounding stud in the passenger side column. No corrosion.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Have you check for codes in the front control module? Thats also your BCM ( body control module).
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Four codes were given: P1684 (battery disconnected) and P0442, P0455 and P0456 (leak detected). The battery was disconnected some time ago, when I cleaned the terminals. The electrical problem has been occurring since well before that.
Thanks for any additional suggestions.
More details on the problem: when the key is at the ACC or ON position (van not started) they work fine. Only when the van is actually started, do they not work. All lights, turn signals, etc. work all the time. Also the heater vent controls seem to work all the time, even when the blower will not.
