DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 10-27-2009, 01:07 AM
Saabu2 Saabu2 is offline
Default long-delayed surgery on my 99 3.8L
finally decided to open 'er up: plans included water pump (done), S belt, tensioner (not done), alternator (not done), rear plugs (got #1 in), thermostat, both rad hoses,plug wires
i couldnt get the alternator out because the stupid vertical Alt bracket is in the way and i believe either the tensioner is holding it on, or the final bolt is underneath the tensioner.
to get the tensioner off, almost impossible access from below and since it aint broke, aint fixin. so alternator stays in the van (240,000 kms OE, slightly amazing) until someone explains the bracket question i guess.
should have put it up no ramps before i started....
might have the shop do the two remaining rear plugs as well as the upstream 02 sensor.
By the way there is what Haynes says is the engine block coolant drain plug but that sucka is tight and i dont wanna force it. is it critical? i tipped the van hard to the PS to drain rad and block, seemed to help some more coolant come out...
TIA,
Wayne in Calgary
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-27-2009, 01:14 AM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
The tensioner and the two rear plugs are done from the bottom. Remove the top bracket for the alt and all bolts. It does come out, but takes time. Be cafeful.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 10-27-2009, 09:48 AM
Default ok... let it sit for 2 days and it still isnt loosened...
ha ha JK
ok so clarify if getting the tensioner nut off will either free up the bracket or expose the last bolt holding said bracket on....
is 240,000 kms pretty normal for OE alternator? I'm amazed personally...
any idea about the coolant drain plug/bolt at bottom front of block?
thanks again,
Wayne
Old 10-27-2009, 10:00 AM
92dak5.24x4 92dak5.24x4 is offline
if you take off the wiper unit the alt comes out super easy. it only takes 10 min to remove the wiper unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
