Due to intermittent failures of the instrument cluster, my wife took into one of the local garages while I was out of province last year. Said garage replaced instrument cluster with a used one. Worked for a bit and then started acting up again. Same story next time she took it in. Wife said it seem to be worse in wet weather (though I have personally seen it die during this hot last summer). The unit now displays absolutely nothing except for a couple of momentary lights while starting the vehicle and "Check gauges" constantly on while operating the vehicle.
My Chilton's points to a defective instrument cluster voltage regulator, poor ground etc.
Seems Google only returns hits for such a voltage regulator up to '89; can anyone confirm this?
If indeed, the '91's have a voltage regulator, information as to where it's located on the vehicle would be appreciated.
<added later on>
After reading on similar situations in this forum, I've checked the instrument cluster connectors and AFAICT there are no cold solder joints, loose pins etc.
A website reference to the pinout for this connector and/or location of the grounding point(s) would be really helpful.
Any thoughts, suggestions or references on this topic would be much appreciated...thanks! :-)
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
