DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 11-01-2009, 06:22 PM
bridanmya bridanmya is offline
Default 1996 Plymouth Voyager SE Problem!
Just had a new ECM installed and everything worked good for a couples days but when I locked the door and then unlocked it with the key it sounded off an alarm......headlights flashing 4 ways flashing and horn blowing, thing is i was told this doesnt have an alarm? Any the key is just a copy with no alarm switch! I just bought this and the previous owner has never had this problem. I can't not find how to shut it off and when u turn the car on it still does it. It will do it for like 5 mins then tun off then randomly start again wheather the car is on or off? Any ideas thanks I have tried un hooking battery to reset it and it still does it
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-01-2009, 10:48 PM
master tech master tech is offline
Vehicle: Mits P/U , Dodge avenger(1996) .
Send a message via Yahoo to master tech
You should have an alarm reset on the inside of the driver door, when you have the key in the lock turn to unlock and it should reset. You may want to ck to see if a skim module in the van.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old 11-02-2009, 12:14 AM
What is a skim module and where is it located? Is there a way to disable the alarm, if so where is it and how do i do it thanks
Old 11-02-2009, 01:45 PM
Its part of the BCM ( body control module ).What you need to do is take the van to the dealer and have them hook up the DRB3 and look at the door triggers. One of the door triggers maybe bad, most the time its the driver door.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
