DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 11-03-2009, 11:37 AM
Budisstrange Budisstrange is offline
Default 1996 Dodge Caravan Slider won't open
Drivers side slider door.
I removed the panel from the inside and tried to open manually, no luck. There is an override that when the gas door is open the slider won't open. There is an inspection hole on the inside and gas door override appears to functioning properly. I can put my hand on the latch and manually pull the release but nothing. It acts as though the latch is broke. It appears the only way to remove the latch is to have the door open. Is there someway other than destroying the door to open if the latch is broke?
Thanks in advance to anyone that can help
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-03-2009, 11:56 AM
circumventor circumventor is offline
aint no connection between gas door and slider door i seen allot of minivan gas doors missing cuz of the slider whackin them. yall gotta feel around in the door latch and find the trip levers i had one that the power lock jambed the latch so i had to do what yall did pull the pannel and get my hand in there to release the latch.
Old 11-03-2009, 10:25 PM
Default Door won't open
When the door was working, if you opened the gas door the slider won't open. There is a wire on the gas door that jams the latch of the slider door so it won't open. I can see the wire clear up to where it goes to the latch and when you open the gas door the wire moves, so I am assuming that it is not the problem. I can see the latch and get my hand and feel around, it sure don't feel like there is any trip wire except the one that goes to the door handle. No matter how hard I pull on the release lever, nothing happens.
Old 11-04-2009, 09:20 AM
ok yall, i ckecked a few 96s we got around hear. and what i found is everyone of them opnes like to a first click as if you didnt shut her tight so does yalls door do that? or dont she open at all?
Old 11-04-2009, 11:21 AM
Default Slider door won't open
The door is in normal closed position and will not open.
Old 11-04-2009, 12:16 PM
then yalls prob aint in the gas door latch need to figgure out the regular door latch cuz she's probly stuck
Old 11-06-2009, 11:03 AM
46FD04 46FD04 is offline
My brother-in-law's 1997 van did the same thing. To get it open, try this VERY CAREFULLY!
Have someone on the outside hold the door handle open.
Then you go inside, and gently kick the rear portion of the door, where it pops open first. This may work.
If it doesn't, I'd check the door lock mechanism. Maybe the lock is not unlocking when you lift the lock tab.
It is a pain, I know.
After a while, my brother-in-law's door would not open at all, and he just gave up. He never got it fixed.
Good luck!
Old 11-06-2009, 09:29 PM
Default Stck Door
Thanks, We tried kicking the door while door latch pulled, nothing. I'm convinced the door latch is broken. I read somewhere else that someone used a sawsall to cut off the latch. I think that's what I'll have to do.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
