1995 Grand Caravan lost cruise control
I have a 1995 Dodge Grand Caravan.
I was driving home today on the highway, at about 60mph using my cruise control when it suddenly lost... cruise control.
What should I check to diagnose the problem? I have a 6 cylinder 3 liter engine with overdrive. The cruise is completely non-functioning. Everything else appears to be working normally.
No, the air bag light is not on. As I said, everything else appears to be working normally. I just ordered a Haynes repair manual (I've checked it out of the library numerous times, figured I'll get one of my own) so when it arrives I will be able to locate the speed control servo to check it.
Oddly enough, it worked today as if nothing happened to begin with. The only things I did to check it so far were to pull the fuse to see if it was blown, and look by the brake pedal for the stop light switch, which I didn't actually touch, only moved the brake pedal a few times to see where it was.
I guess I'll see if it keeps on working...
