07 GC airbag codes
07 GC airbag codes
Can anyone explain the following airbag codes. No numbers, just "DCT";
1. No Odometer Message Received
2. Vehicle Body Style Unknown
3. No Cluster Message Receive
The airbag warning light stays on. Vehicle has salvage title, but the state DMV inspection certified that the airbags did not deploy. Any ideas?
on
You may need to go to the dealer for this.Symptom:
*AIRBAG INDICATOR ON WITHOUT ACTIVE TROUBLE CODES
POSSIBLE CAUSES
AIRBAG WARNING INDICATOR ON WITHOUT ACTIVE TROUBLE CODES
INSTRUMENT CLUSTER PROBLEMS
TEST ACTION APPLICABILITY
1 NOTE: Ensure the battery is fully charged.
Turn the ignition on.
Make sure that all active DTC’s have been repaired before performing this procedure.
With the DRBIIIt select the PASSIVE RESTRAINTS, AIRBAG, MONITOR DISPLAY
and read the WARNING LAMP STATES.
With no active DTCs, Does the LAMP REQ by ACM monitor show ON?
All
Yes ! Replace the Airbag Control Module in accordance with Service
Instructions.
Perform __AIRBAG VERIFICATION TEST - VER 1.
No ! Refer to INSTRUMENT CLUSTER CATEGORY symptom list for
problems related to Instrument Cluster.
NOTE: When reconnecting Airbag system components, the ignition must be
turned off and the battery must be disconnected.
POSSIBLE CAUSES
All
Instructions.
