engine code P1294
on
Welcome to DF
Symptom:
P1294-TARGET IDLE NOT REACHED 3.3L/3.8L
When Monitored and Set Condition:
When Monitored: With the engine idling and the transmission in drive, if automatic.
There must not be a MAP sensor trouble code or a Throttle Position Sensor trouble code.
Set Condition: The engine idle is not within 200 rpm above or 100 rpm below the target
idle for 40 seconds. One trip fault.
POSSIBLE CAUSES
INTERMITTENT CONDITION
IAC MOTOR PASSAGES
VACUUM LEAKS
AIR INDUCTION SYSTEM
THROTTLE BODY AND THROTTLE LINKAGE
TEST ACTION APPLICABILITY
Symptom:
POSSIBLE CAUSES
IAC MOTOR PASSAGES
VACUUM LEAKS
