Smoking
Smoking
it seems that ever since I changed the MAP sensor my 3.0 started smoking but only when it sits for a minute while running then no smoke while driving, but here is whats strange. it has a sulfur type smell to it. would that be the EGR valve any help would be greatly appreciated. thank-you
Model year?
Only reference to a sulfur smell I've read is either the catalytic converter is eating itself or the battery is shorted and overheating. In your case I would suspect the cat converter considering you just changed a major component that effects the air/fuel ratio in the MAP sensor. That said, if it's so bad you're smelling sulfur fumes I would expect the SES light is on indicating codes are present. You can cycle the key to read them or head to an Autozone or the like and have them read with a scanner for free.
