grand caravan 2000 speedometer & odo problems
#32
no, it seams to not stick ( it stick from 1st to 2nd and remain there
I didn't replaced any part, it just stoped to show the speed and the number of miles while drivind, it stoped on the miles when the speed was working.
About the obd, it is not working to connect to the laptop. I checked with other cars and the obd from laptop it is just working fine.
THe speed sensors will come next week, but I'm asking now why the obd don't want to work.
Thanks a lot,
Thanks a lot,
#34
#35
Yes, I'm just waiting the sensors.
About OBD: ok, I have the connector OBDII, it enter on the OBD socket of the car and connect USB on the laptop
When I plug in the connector on the OBD of the car it just not connect with the software from the laptop even one led from the reader it show the I have power on OBD
It is really strange because the same device it is working on other cars. OBDII it is standard, so normal shoud connect with any car wich comply OBDII standard
#38
PCM's have 2 different sections. OEM and OBDII. all cars are required to use the same protocol for Global OBDII.
however no matter how much you want to access obd, this still isn't going to give you the transmission access information you need! only a quality scanner (not a code reader) will allow access to other computers
#39
OBD-II Signal Protocols
There are five signalling protocols currently in use with the OBD-II interface. Any given vehicle will likely only implement one of the protocols. Often it is possible to make an educated guess about the protocol in use based on which pins are present on the J1962 connector:
- SAE J1850 PWM (pulse-width modulation - 41.6 kB/sec, standard of the Ford Motor Company)
- pin 2: Bus+
- pin 10: Bus–
- High voltage is +5 V
- Message length is restricted to 12 bytes, including CRC
- Employs a multi-master arbitration scheme called 'Carrier Sense Multiple Access with Non-Destructive Arbitration' (CSMA/NDA)
- SAE J1850 VPW (variable pulse width - 10.4/41.6 kB/sec, standard of General Motors)
- pin 2: Bus+
- Bus idles low
- High voltage is +7 V
- Decision point is +3.5 V
- Employs CSMA/NDA
- ISO 9141-2. This protocol has an asynchronous serial data rate of 10.4 kBaud. It is somewhat similar to RS-232, but that the signal levels are different, and that communications happens on a single, bidirectional line without extra handshake signals. ISO 9141-2 is primarily used in Chrysler, European, and Asian vehicles.
- pin 7: K-line
- pin 15: L-line (optional)
- UART signaling (though not RS-232 voltage levels)
- K-line idles high
- High voltage is Vbatt
- ISO 14230 KWP2000 (Keyword Protocol 2000)
- pin 7: K-line
- Physical layer identical to ISO 9141-2
- Data rate 1.2 to 10.4 kBaud
- Message may contain up to 255 bytes in the data field
- ISO 15765 CAN (250 kBit/s or 500 kBit/s). The CAN protocol is a popular standard outside of the US automotive industry and is making significant in-roads into the OBD-II market share. By 2008, all vehicles sold in the US will be required to implement CAN, thus eliminating the ambiguity of the existing five signalling protocols.
- pin 6: CAN High
- pin 14: CAN Low
