2000 caravan engine removal
I have a 2000 caravan 3.3L I am in the process of swaping the old engine out and was wondering if there was any way that the engine can come out from the top or does it have to come out from the bottom. Everywhere i look it is saying from the bottom but from what i am looking at it seems i could pull it out of the top???
I always pull these engines out the top. there's plenty of room. I found I had to remove the water pump and crank pulley for enough clearance. remove upper radiator support and remove hood and wiper module assembly. then it gets really easy. i didn't remove the radiator just the fans. leave A/C compressor in the van along with PS. I also pulled off the upper intake.
torque converter bolts are the easiest thing of the job, I always hated having the messy stuff like cooling hoses. you'll want to remove the crank pulley for more clearance which requires a special puller. you can try without but I found the $50 I spent on the puller was well worth the cussing and fighting I went through on the first one.
