Need help replacing transmission shift solenoid
Now I am even more confused. I know that every manufacture loves to mix stuff up in ways that repair manuals dont seem to indicate, so I assume it may be an overdrive tranny as a simple matter of anything is possible. I have no ego here, so I can be wrong & it wont matter, I just want to get the thing fixed. Oreiley's website has 2 options for solenoid, please look at these & give me your thoughts. The first one is cheap. I would love it to be that. Okay, a quick note on what is going on. It shifted fine when I got it, then in the butt-cold of Iowa winter, it starting going back & fourth between 1 & 2 gears, then if I hit a bump it would shift normally until a small bump came around again. I am about to trade my car for this van to a good friend of mine. My car gets aweful mileage so this trade is good for me. I am going to trade her as soon as she gets the part then I will own the van.
http://www.oreillyauto.com/site/c/de...ssion+solenoid
This is good then. I did go look at the van, and confirmed there is indeed no overdrive on the selector. The lady I am getting this van from from describes her issue like this, and keep in mind a local tranny shop told her it was the solenoid, but not the tranny shop I usually go to. Her description - .I can b driving or just sitting @a stop sign and I can feel it shift rather hard, then it won't shift again after that. I've tried letting off the gas to try to help it shift n it doesn't help. It doesn't do it with any predictability. Only occasionally. My fluid levels are fine. - So, now that I know there is no solenoid pack, and the tranny shop said it needs a new solenoid, what else do you guys think it could be?
03 GC solenoid pack
I'm replacing the trans solenoid pack on an 03 GC and have looked it over to see what I'm up against... master tech's step by step above sounds good but I'm wondering if all those will apply to my 03? It doesn't look like the air cleaner, TCM and maybe the input speed sensor have to come out? Definately the cooling lines and radiator overflow... is this model specific?
Question for Maser Tech... after reviewing the information you have provided in this trread, I would like to say they are very clear and seem easy to follow.
I noticed that in this thread, you were giving the step by step instructions for replacing a transmission shift solenoid for a 2000 caravan.
I am wondering if the same steps hold true for a 2005 grand caravan
Also... I have read that a person should not use Dextron ATF in a Dodge transmission.
Any thoughts on that?
Also... I have heard that Lucas Transmission Fix stops slip, hesitation and rough shifting in worn transmissions and is a great product.
when I go to buy the parts I need -- should I go ahead and replace the TCM too? I am having some shifting issues... up and down... seems to have lag time and shifts hard.
finally... do I need to know what kind of transmission I have (model number) in order to buy the correct parts (TCM; solenoid pack or shift solenoid; and the Speed Sensors -- i think there are two types, right)?
I have NO idea what kind of tranny I would have in my 2005 Grand caravan.
Needing some more info, please.
I am wondering if I need to do the re-learn after I am done with the replacement. Also, do you know of a good video of the step-by-steps on the trans solenoid? Any help would be great. Thank you.
