clockspring install problem - DodgeForum.com
Old 05-29-2011, 11:50 AM
rick31797
rick31797 is offline
Default clockspring install problem
I decided too install the new clock spring today, everything went smooth except when i come too the part too release the spring.. there is a long pull tab..and i cannot see how too release this.
I am afraid i am going to break the unit prying and pulling at it.. Also can this clockspring be released after installed, or should the steering wheel be on.. it would make it harder too get at..depending how u do it.<
IF anybody has done this can you please explain the steps.. here is a picture at the top you will see a long plastic tab.
the clock spring is for a 2002 caravan.
Old 05-29-2011, 02:43 PM
rick31797
well i finally got the tab out too release the spring, and all back together, the bad news is the airbag light is still on... i wonder if it just needs to cycle or there is another problem.
Old 05-29-2011, 04:58 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Does the horn blow? If it doesn't, did make sure the two connectors are plugged into the clockspring thats inside the column covers.
Old 05-30-2011, 01:18 PM
rick31797
Default clockspring
before i changed the clock spring the horn worked and cruise worked, since i put the new clock spring in they are still both working, so from what i read it could be alot of things..
I think if the clock spring is gone, there needs too be something more wrong then the airbag light on, like the horn or cruise or both..
I may try a new air bag module, but really a guessing game with having it scanned.
Old 05-30-2011, 01:22 PM
06bighorn06
06bighorn06 is offline
Hey, I'm new to forums and wondering how to create a new post. Can anyone help/
Old 05-30-2011, 02:34 PM
modain's Avatar
modain
modain is offline
You press the "New Thread" button.
Related Topics
Thread
Forum
Replies
Last Post
SteveTangential
1st Gen Ram Tech
4
09-10-2015 10:38 AM
johncrawford1
Dodge/Ram Diesel
0
07-14-2015 10:08 AM
bigearl
2nd Gen Ram Tech
12
07-12-2015 09:55 PM
CharlesShaheen
2nd Gen Intrepid
0
07-11-2015 10:35 PM
roadhammer1971
2nd Gen Ram Tech
16
07-07-2015 11:12 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
