Fuel Filler Tube 1996
Old 06-13-2011, 11:37 AM
Robk1971's Avatar
Robk1971
Robk1971 is offline
Default Fuel Filler Tube 1996
Hi all,
I have to replace my fuel filler tube on my 96 Caravan. Fortunately it looks like an easy swap but the dealer is saying the prices range from $200 to $400. I have to get my VIN number for them to source the correct part. Online aftermarket prices range from $50 to $115.
If a VIN number is needed for the dealer to source the correct part, how can I make sure I order the correct aftermarket part? Anyone done this fix, gone the aftermarket route, and know the differences?
Judging by how rusted mine is I don't expect much success from the wrecking yard.
Thanks!
Rob
Old 06-13-2011, 12:34 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Do you have a long wheel base or short wheel base? And did the dealer give a part number?
Old 06-13-2011, 12:53 PM
Robk1971's Avatar
Robk1971
Robk1971 is offline
I have the short wheel base 3.0L. I still have to get my VIN before the dealer can source the correct part and I have to wait until after work to get that. My existing tube appears to have two vent pipes attached if that helps.
Old 06-13-2011, 02:26 PM
master tech
I found an old TSB. Did you ever have any recalls done on the van? Because there is one to replace the filler neck assy.
December, 1995
To: All Dodge and Chrysler-Plymouth Dealers
Subject: Safety Recall #665 -- Fuel Filler Tube Rollover Valve and Ground Strap
Models:
1996 Model Year Dodge Caravan and Grand Caravan; Plymouth Voyager and Grand Voyager; and Chrysler Town & Country Minivans (NS) Built Through:
• August 9, 1995 (MDH 080910) at the St. Louis Assembly Plant (‘B' in 11th VIN Position)
• August 10, 1995 (MDH 081018) at the Windsor Assembly Plant (‘R' in 11th VIN Position)
The fuel tank rollover valve on the above listed vehicles, may allow liquid fuel to pass into the vapor canister under certain circumstances. Also, an electro-static charge may build up on the filler tube and cause a spark when refueling. Either of these conditions create the potential for a vehicle fire. To correct these conditions, the fuel tank filler tube must be replaced with a filler tube which incorporates a third rollover valve and a ground strap. Also, the fuel tank vent hoses must be rerouted.
Fuel Filler Tube Packages, Recall PN CBK06651 for long wheelbase vehicles and PN CBA06652 for short wheelbase vehicles.
Each parts package contains the following components:
Quantity
Description
Quantity
Description
1
Filler Tube with ground strap
1
O-Ring-- 9/16" Vent Tube
1
Hose -- Canister-Filler Tube
1
O-Ring-- 3/8" Vent Tube
1
Hose Harness -- Rollover
1
Retainer-- 9/16" Vent Tube
Valve-to-Filler Tube
1
Retainer --3/8" Vent Tube
1
Tie Strap -- Medium
1
Completion Label
4
Tie Strap -- Small
1
Instruction Sheet
4
Push Clips
Old 06-13-2011, 03:13 PM
Robk1971's Avatar
Robk1971
Robk1971 is offline
I bought the van used and the dealer I go to didn't find any outstanding recalls. The existing filler tube does in fact have a ground strap so I guess it has been done. Too bad, it could have been a free fix:-(
Quick Reply: Fuel Filler Tube 1996
