How Much Oil in 2011 Caravan?
on
The spec is 5.6 liters on engine oil. So if you add 6 qts of oil, you will be just a bit over on the stick. Also remember if no one has say it before. Remove the filter first and leave it out and then change the oil and then put the new filter in. That's because the filter will maintain at least 1/2 qt of oil.
