2008 dodge caravan check engine light - DodgeForum.com
Old 01-10-2012, 09:33 PM
Dieselpower1988
Dieselpower1988 is offline
Default 2008 dodge caravan check engine light
I have a problem with m 08 dodge caravan. The gascap light came up on the dash. I replaced the gas cap with a new one and reset the light. One drive and the lights back up but with a check engine light now. I looked up the code and it comes up with small emissions leak. Where do I start in diagnosing the leak and where is the system? Thanks in advance for any help
Old 01-10-2012, 09:51 PM
steak59
steak59 is offline
Where did you get the Gas Cap? as for Gas cap, you HAVE to use oem cap from dealership. caps from parts store doesn't fit properly.
Old 01-10-2012, 09:54 PM
Dieselpower1988
Thanks for the reply. Got the gas cap from dodge dealership.
Old 01-10-2012, 10:24 PM
steak59
steak59 is offline
If the gas cap is factory, you might need to Smoke the gas tank and look for a leak with Smoke machine.
But If I have to take a guess and throw a part at it, it will be the ESIM switch on the Charcoal canister, fairly common failure on Chrysler vehicle. and probaly cheaper than the gas cap.
The charcoal canister is attached to the Back of the Gas tank, ESIM switch is the White piece on the canistor, it looks like this.
Note: Not all of them are Colored white, few of them are colored black. And should take you no Longer than 15 minute to replace once you are under the car.
Make sure you jack up the car properly and sit on Jack stand, these Vans are heavy.
Remember to Lubricate the seal between canister and ESIM switch with some grease to help seal better.
To reset the GAS CAP light on the dash, you have to disconnect the battery for few minute, the Code reader does NOT clear the message on the dash.
read this article if you want to know more about it.
http://motorage.search-autoparts.com.../detail/615203
Old 01-10-2012, 11:31 PM
Dieselpower1988
Thanks for the info. Will check that tomorrow I post results.
Old 06-11-2013, 07:28 PM
jeedee
jeedee is offline
Hi Steak59
I am having a similar issue, the engine light went on, I took car to dealer and told me I need to change the canister and the ESIM, are these two easy to change
Is it something I could do my self?
Also is there anyway you can repost the pictures
Thank you
Related Topics
Thread
Forum
Replies
Last Post
ryderczar
New Member Area
3
07-03-2015 05:19 AM
sonstruck
2nd Gen Ram Tech
2
07-02-2015 12:57 AM
ChargerGal
Dodge Charger
5
06-29-2015 01:49 PM
jlbrennan
Audio/Visual Electronics
0
06-25-2015 10:56 AM
nlehew
General Tech
0
07-16-2003 04:13 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
