Odd tail/turn signal problem
Old 05-01-2012, 03:23 PM
hambone1949's Avatar
hambone1949
hambone1949 is offline
Question Odd tail/turn signal problem
While driving our 1998 Grand Caravan recently with the lights on in the rain a warning chime came on, as well as the right turn indicator dimly and steady. A check of the exterior lights indicated the right front parking light and lower right taillight bulb were both burning brighter than usual. The top right taillight was, or appeared to be, slightly dimmer. A check of the right turn signal showed both front and rear right signal bulbs indicating only slightly brighter than as parking/taillights alone. When the parking/driving lights are turned off, the right signal flashes as normal, but both LEFT taillight bulbs come on dimly in synch with the right signal.
Swapping around bulbs only, bulbs in sockets, even switching the entire rear light assemblies left and right, has no effect on the problem.
Brake lights work normally. The 4-way flashers appear to be working normally, except both the upper taillights come on dimly in synch with the flashers. Is this normal?
The car has a factory towing wiring harness. One day earlier we had been towing a trailer and had not noticed this as a problem. The vehicle is very new to us, so we have no idea if there it has any kind of a history of this.
Thanks much.
Old 05-01-2012, 07:52 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Normal? No. The tow harness connection is suspect number one. It may have gotten wet and shorted something in the circuit. Dry it thoroughly with a hair dryer. Make sure the harness hasn't chaffed structure and shorted to ground. Other than that try reseating the combination flasher module on the interior fuse panel (left of driver under the dash). You may have to replace it.
Old 05-02-2012, 12:38 PM
hambone1949
You were correct. Starting at the connector I unwrapped the cable to reveal a bunch of wear damaged and poorly repaired wires that obviously had gotten wet and shorted one to another.
All better now. Thanks!
Old 05-02-2012, 08:40 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Congtats! Glad to hear all is well.
Quick Reply: Odd tail/turn signal problem
