2002 dodge grand caravan
Old 07-05-2012, 10:57 PM
carlitoz's Avatar
carlitoz
carlitoz is offline
Default 2002 dodge grand caravan
my van keeps ****ting off wen im at stop,i have replaced altanator.plugs,wires,crank sensor,cam sensor ,coil pack and pcm....what else can it be??? please help
Old 07-05-2012, 11:24 PM
dsolorio's Avatar
dsolorio
dsolorio is offline
What size engine do you have? Have you tried cleaning the IAC and TPS? Can you give more details like, does it idle down then shut off or just stop without warning, does it start right up or trouble, when not in gear is it fine or die as well, when you come to a stop and keep your foot lightly on the gas will it stay on or still shut off? I'm just asking for more detail.
Old 07-05-2012, 11:28 PM
carlitoz's Avatar
carlitoz
carlitoz is offline
3.3 v6 engine,just stops without warning and it starts right away and only dies in gear and i havent tried lightly steping on gas wen im stoped ..how do you clean the IAC and TPS
Old 07-05-2012, 11:29 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Also adding, is the check engine light on? And does engine stall as so as you put the transmission into gear?
Old 07-05-2012, 11:31 PM
master tech
I guess we were typing at the same time. It maybe the torque converter in lock up when it shouldn't.
Old 07-05-2012, 11:36 PM
carlitoz's Avatar
carlitoz
carlitoz is offline
no check engine light on and it runs good for a while, it doesnt shut off wen i put it in gear it runs for a while but it has shut off like 10 times today
Old 07-05-2012, 11:39 PM
master tech
I would see if the dealer can hook up a flight recorder and see it can take snap shot on whats making van to shut off.
carlitoz's Avatar
carlitoz
carlitoz is offline
no rough idle no shaking just shuts off like power cuts off somewhere
Old 07-05-2012, 11:49 PM
carlitoz's Avatar
carlitoz
carlitoz is offline
would a bad TPS or IAC make it shut off?
Old 07-10-2012, 03:42 AM
carlitoz's Avatar
carlitoz
carlitoz is offline
another question..on the cam position sensor do you have to have that gasket on
Quick Reply: 2002 dodge grand caravan
