Go Back   DodgeForum.com > Dodge Vans & CUVs > Dodge Caravan
Sign in using an external account
Register Forgot Password?
2002 Grand Caravan won't move in any gear
Thread Tools Search this Thread
Old 11-01-2012, 07:42 AM
mrs4dtough mrs4dtough is offline
Garage is empty, add now
Default 2002 Grand Caravan won't move in any gear
Hello,
I was driving my 2002 Grand Caravan yesterday when it abruptly stopped moving, felt like the brakes were slammed on. I had just started going in a parking lot when it happened so it was at low speed. Now it does not move in any gear but will roll in neutral with the key off. P0700 and P0720 were the codes. My husband says that he was able to get the van to move a short distance (inches) in drive when he pushed hard on the accelerator. He also says that when it is put in reverse it lurches forward like it was shifted into drive. Transmission fluid is red, doesn't have any burnt odor & is full.
Could this be a problem with the TCM, the solenoid pack or the speed sensor, or is it something internal?
Any insight would be appreciated!!
Thanks for your time,
Christie
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Old 11-01-2012, 12:29 PM
Cougar41 Cougar41 is offline
Could this be? Yes, all the above but the output speed sensor circuit is suspect #1 according to the code. That eliminates the solenoid pack for now. What's not making sense in reading forums for many years I don't think I've ever read of a speed sensor circuit failure causing no shifting whatsoever and locking up the transmission. You may have more problems then the speed sensor circuit. Course I'm not a tech either.
Considering just the code the output speed sensor is the most likely culprit and is the fix most of the time. It's located on the front right of the transmission. They cost around $40 but prices vary. Check the connector for corrosion and security. Remove it with a socket/ratchet. You can test it and the wire harness with a multimeter. Just be aware the TCM and PCM can also cause the signal to fail. If you ever get it moving again you should notice the speedometer is dead or erratic. It uses the output speed sensor as a signal source.
__________________
We took the time to answer your post. Please give us some time and post the fix. You'll help hundreds!
Old 11-01-2012, 04:52 PM
Thanks! My husband is going to try replacing the speed sensor this evening.
Old 11-01-2012, 06:34 PM
My husband put the van on his lift and took off the transmission pan, it had several metal pieces in it that were about 1/8" in size.
Old 11-01-2012, 07:26 PM
Ouch! I don't need to say the obvious. Sad to say even if you get it rolling you're on borrowed time.
__________________
Old 11-02-2012, 10:57 PM
master tech's Avatar
master tech master tech is offline
Multi-section Moderator
Vehicle: Mits P/U , Dodge avenger(1996) .
Leonard Pierce
You may have notice a lot of metal on the output sensor too. Thats okay cougar, i'll say it. The planetary most likely came apart. Causing you to lose all forward gears.
__________________
Dodge Master Tech.
Old 11-08-2012, 10:36 PM
homedad42 homedad42 is offline
Sounds like a rebuilt transmission is in order
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join DodgeForum
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Internet Brands, Inc.
Contact Details & Emails
Search Engine Friendly URLs by vBSEO 3.5.2
