1999 Dodge Caravan starting problems - DodgeForum.com
Old 04-21-2013, 08:45 PM
stevesmustangs67's Avatar
stevesmustangs67
stevesmustangs67 is offline
Default 1999 Dodge Caravan starting problems
I have a 1999 Dodge Caravan that is hard to start, you have to press gas pedal about 1/4 throttle to start. I hear it can be crank sensor, fuel pump, fuel filter, or broken fuel lines. It runs great after it is started. It's my daughters van and she is going to college in fall and i want to get it running in tip top shape for her. She said that she paid someone to put a fuel pump and fuel filter on, i gotta check and see for myself. I will go to autozone and borrow fuel pressure checker, what should fuel pressure be? Any other suggestions would be appreciated. The air filter is new, i am gonna put a tune-up on it all. Thank you in advance.
Old 04-21-2013, 10:11 PM
jkeaton is offline
Site Moderator
Welcome to DF! I will move this to the correct section.
Old 04-22-2013, 11:07 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Did the check engine light come on? You should need to push the gas pedal down to start the engine. Check and see if you have any stored or active codes in the van.
Old 04-22-2013, 11:57 AM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
Try giving the throttle body a good cleaning, could be plugging the bypass so you need to open the throttle to get some air intake.
Old 04-22-2013, 05:20 PM
Cougar41
Cougar41 is offline
Fuel pressure should be 49 psi on a 3rd generation van - yours. I'll second the TB cleaning. Open the throttle plate and clean the area behind it. That's where the IAC orifice opens to let air bypass the throttle plate.
Old 04-22-2013, 06:18 PM
jehiatt
jehiatt is offline
Default typo/
shouldn't gas pedal NOT need to be pressed for cranking. ?
Old 04-23-2013, 12:06 PM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
Yep, should have been a "not" in there
Old 04-23-2013, 02:12 PM
Cougar41
Cougar41 is offline
Splitting a few hairs but what Tizzy1 was saying in post #4 is you are having to open the throttle to get air BECAUSE the IAC bypass orifice in the throttle body may be clogged. Didn't need the word "not".
Old 04-23-2013, 03:59 PM
stevesmustangs67
Thankyou, i will try that, it used to start up without touching throttle, it just started acting up. thankyou
Old 04-23-2013, 04:01 PM
stevesmustangs67
The check engine light isnt on, i just took it for recall last week for the clock wire recall, the horn and cruise control stopped working and airbag light stayed on but all good now, im gonna try cleaning like you all said
Related Topics
Thread
Forum
Replies
Last Post
banshee8999
Dodge/Ram Diesel
1
07-04-2015 08:34 PM
cg1996
2nd Gen Ram Tech
9
07-04-2015 11:20 AM
noureddineb@gmail.com
Dodge Caravan
1
06-30-2015 02:05 PM
jlbrennan
Audio/Visual Electronics
0
06-25-2015 10:56 AM
cliffoverton
General Tech
4
06-01-2003 12:50 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
