p0205 p0305 help 98 caravan 3.0
Old 04-28-2013, 01:27 AM
mudduc971's Avatar
mudduc971
mudduc971 is offline
Default p0205 p0305 help 98 caravan 3.0
i have a 98 caravan 3.0 that has p0205 p0305 codes i know the two are related i have replaced the number 5 injector and there is no signs of the harness being melted or messed up in any way but im still having the same codes and the same problems with the van ie. hessitation at take off/ low rpms it runs fine when its cold but when it warms up is when its problematic here is a list of what i have replaced on it in the last couple weeks granted some of these have nothing to.do with the problem plugs, wires, cap, rotor, pvc, fuel pump, fuel filter, number 5 injector anyone with any suggestions please help..
Old 04-29-2013, 11:37 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Symptom:
P-0205 INJECTOR #5 CONTROL CIRCUIT
When Monitored and Set Condition:
When Monitored: With battery voltage greater than 12 volts, the auto shutdown relay
energized, injector pulse width less than 10ms, and engine speed less than 3000 rpm.
Set Condition: This trouble code takes .64 to 10.0 seconds to set when no inductive kick
is sensed .18ms after injector turn off, and with no other injectors on.
POSSIBLE CAUSES
ASD RELAY OUTPUT CIRCUIT OPEN
INJECTOR #5 DEFECTIVE
INJ #5 CONTROL CIRCUIT WIRING HARN (ENGINE OFF)
INJ #5 CONTROL CIRCUIT WIRING HARN (ENGINE ON)
INJECTOR #5 DRIVER CIRCUIT OPEN
INJECTOR #5 DRIVER CIRCUIT SHORT TO GROUND
INJECTOR #5 DRIVER CIRCUIT SHORTED TO GND
INJECTOR #5 DRIVER CIRCUIT SHORTED TO GROUND
PCM DEFECTIVE
POWERTRAIN CONTROL MODULE DEFECTIVE
TEST ACTION APPLICABILITY
277 Ignition Off
Start engine, let idle for at least 20 seconds.
Key on, engine off.
With the DRB, read Trouble Codes.
Does the DRB show 9Injector #5 Control Circuit9 with a start run count of zero?
ENGINE - 3.0L V6
Yes ® Go To 278
No ® Go To 289
278 Ignition Off
Disconnect the Injector Harness Connector.
Note: Check connectors - Clean/repair as necessary.
Use an ohmmeter in the following step.
Measure the Injector #5 Driver Circuit to the ASD Relay Output.
Is the resistance between 10.0 and 16.0 ohms?
ENGINE - 3.0L V6
Yes ® Go To 279
No ® Go To 284
279 Ignition Off
Using an Ohmmeter, measure the Injector #5 Driver Circuit to ground.
Is the resistance below 5.0 ohms?
ENGINE - 3.0L V6
Yes ® Repair the Injector #5 Driver Circuit for a short to ground.
Perform Powertrain Verification Test VER-5A.
No ® Go To 280
280 Ignition Off
Key on.
With the DRB, actuate the Auto Shutdown Relay.
Using a Voltmeter, measure the ASD Relay Output Circuit.
Does the voltage cycle high and low?
ENGINE - 3.0L V6
Yes ® Go To 281
No ® Repair the open ASD Relay Output Circuit.
281 Ignition Off
Disconnect the Powertrain Control Module.
Measure the Injector #5 Driver Circuit from the PCM to the Harness Connector.
ENGINE - 3.0L V6
Yes ® Go To 282
No ® Repair the open Injector #5 Driver Circuit.
282 Ignition Off
ENGINE - 3.0L V6
No ® Go To 283
283 If there are no potential causes remaining, the Powertrain Control Module is
assumed to be defective.
View repair options.
ENGINE - 3.0L V6
Repair
Replace the Powertrain Control Module.
284 Ignition Off
Note: It may be necessary to remove the Intake Plenum in the following
steps.
Disconnect the Injector #5 Connector.
Key on.
Using a Voltmeter, measure the ASD Relay Output.
ENGINE - 3.0L V6
Yes ® Go To 285
285 Ignition Off
step. Refer to the Service Manual for removal instructions.
Use an Ohmmeter in the following step.
Measure the resistance of Injector #5.
ENGINE - 3.0L V6
Yes ® Go To 286
No ® Replace the Fuel Injector.
286 Ignition Off
steps.
Using an Ohmmeter, measure the Injector #5 Driver Circuit from the Harness to the
Injector.
ENGINE - 3.0L V6
Yes ® Go To 287
287 Ignition Off
Disconnect the Injector #5 Harness Connector.
Using an Ohmmeter, measure the Injector #5 Driver Circuit to ground (Injector side).
ENGINE - 3.0L V6
No ® Go To 288
288 If there are no potential causes remaining, the Powertrain Control Module is
ENGINE - 3.0L V6
Repair
289 Ignition Off
Using the schematic as a guide, inspect the Wiring and Connectors.
Were any problems found?
ENGINE - 3.0L V6
Yes ® Repair as necessary.
No ® Go To 290
290 Engine Running
Wiggle Wiring Harness from the Injector to the PCM.
Does the engine miss or stall?
ENGINE - 3.0L V6
Yes ® Repair as necessary where wiggling caused the problem to
appear.
No ® Test Complete.
291 Ignition Off
Key on, engine off.
ENGINE - 3.3L V6
and/or ENGINE -
3.8L V6 and/or ENGINE
- 3.3L V6
FFV
Yes ® Go To 292
No ® Go To 297
292 Ignition Off
Disconnect Injector #5 Connector.
Key on.
ENGINE - 3.3L V6
and/or ENGINE -
- 3.3L V6
FFV
Yes ® Go To 293
293 Ignition Off
Using an Ohmmeter, measure resistance of Injector #5.
ENGINE - 3.3L V6
and/or ENGINE -
- 3.3L V6
FFV
Yes ® Go To 294
294 Ignition Off
Using an Ohmmeter, measure the Injector #5 Driver Circuit from the PCM to the
Injector.
ENGINE - 3.3L V6
and/or ENGINE -
- 3.3L V6
FFV
Yes ® Go To 295
295 Ignition Off
ENGINE - 3.3L V6
and/or ENGINE -
- 3.3L V6
FFV
No ® Go To 296
296 If there are no potential causes remaining, the PCM is assumed to be defective.
ENGINE - 3.3L V6
and/or ENGINE -
- 3.3L V6
FFV
Repair
Replace the PCM.
297 Ignition Off
ENGINE - 3.3L V6
and/or ENGINE -
- 3.3L V6
FFV
No ® Go To 298
298 Engine Running
ENGINE - 3.3L V6
and/or ENGINE -
- 3.3L V6
FFV
appear.
No ® Test Complete.
Quick Reply: p0205 p0305 help 98 caravan 3.0
