[3rd Gen : 96-00]: running bad when warm need advice
Hey everyone I could use some help cause I can't figure this problem out..ok so when my van is cold it runs just fine but when its warm it wants to die and has no power what so ever..it just bogles and spudders bad and if I floor the peddle it juat dies but if I push the peddle maybe a inch or two it
gets up and goes. And when i shut it off when its hpt I have to spray starting fluid in it out it wont start...it back fires a lot and when it does it seems to want to run...I'm confused and frustrated and need help...
Thanks
Thanks
Its a 2000 dodge grand caravan sport 3.3 motor and i have so many theorys on why it wont start but what confuses me is why does it run ok when its cold and only acts up when its hot...but now its having a hard time accelerating when its cold its not to bad but i have to play with the throttle some times to get it to go =/
Mine would run and drive great for about 10mi, then it would start losing power, studdering, backfiring. Then it would die. Then it would have to cool for about an hour before it would start again.
I dealt with this issue for about 2 weeks and 4 shops before I took it into my own hands and found the fuel issue.
