[3rd Gen : 96-00]: 1999 Dodge Caravan Radiator Replacement - Condenser gone WILD
I am trying to replace the radiator on my 1999 Dodge Caravan. I attempted to remove the condenser lines and a lot of green fluid came out under high pressure. I attempted to remove the bolt attached to the top of the condenser on the tube.
Is there a valve I am supposed to close before changing the radiator?
It was indeed the compressor. I ended up over tightening the valve on the manifold and had to replace the entire top ($10 from a junk yard).
About 3 weeks later, the new radiator aquirred a hole. I was able to avoid evacuating all of the freon by removing the coolant radiator without removing the oil and freon radiators.
