[5th Gen : 08+]: cleaning engine
Old 08-16-2014, 12:36 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
DodgeCaravan2010SXT is offline
Default cleaning engine
I have some oil stains on the main intake plastic. I have dirt sand in other areas. can I use any of those store engine cleaners. cover up say the battery. the fuse box. the alternator. then spray chemical. leave 15mins. then rinse off with just a hose. no pressure washer? and then blow out with air and let dry?
Old 08-17-2014, 09:01 AM
DodgeCaravan2010SXT
no one?
Old 08-17-2014, 11:56 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
Blow out the loose stuff with air first, then do the wet cleaning.
Dry it by idling it and burning/vaporizing it all off.
Don't hose down a hot engine with cold water.
Old 08-17-2014, 11:59 AM
DodgeCaravan2010SXT
so as long engine is cool not hot and I wash it keeping best water as far away from the fuse and alternator It should be good?
Quick Reply: [5th Gen : 08+]: cleaning engine
