[4th Gen : 01-07]: 2003 Rear disc brakes
Ok. So I was changing the rear brake pads on my wife's caravan. I was working on the rear passenger side and everything was going perfect.
When I started to bolt the caliper back to the mounting bracket with the 2 screws one of the brackets holes is completely stripped. The bolt is fine and the caliper is fine. The bracket just will not catch the bolt at all. So now I'm stuck with 1 bolt holding my caliper down.
So I guess what I'm trying to say is I need to find a Rear passenger brake caliper bracket.
Really hope someone can help, I've not had any luck so far.
Thanks in advance.
Thanks in advance.
