[5th Gen : 08+]: 2011 Caravan All Instrument Lights On While Driving
Car starts fine, all lights on instrument panel come on and remain on during driving, none of the speed/ fuel/ rpm work or temperature work. When you open door light dont turn on inside but they do work. Unsure what this could be, the odometer is even stuck on the same number all of a sudden. Car drives fine but entire dashboard is light up with all the warning lights and they never turn off.
Yeah, I would assume a cluster malfunction then. Have it pulled and inspected. Any other items down the pipe that might have died should show up in other areas.
I'm sorry to learn of your cluster concern. As @ice445 has stated, it is possible a loose connection or short is present. Your servicing dealer will be able to inspect and isolate the root cause.
